The couplers connect some 180 different I/O terminals with Ethernet TCP/IP. The controller adds an IEC 61131-3 programmable PLC and can be used as a low-cost controller.
Both devices feature an RJ 45 port with an integrated two-channel switch. I/O stations can be configured with line topology via switch or hub, reducing the amount of wiring as well as cabling costs. They support 10 and 100-Mbaud Ethernet with automatic transfer-rate detection. Beckhoff Automation LLC, 12150 Nicollet Ave. S, Burnsville, MN 5537, (952) 890-0000, www.beckhoffautomation.com
