The new variation of ACOPOSmicro drive offers support for servomotors by letting users combine different drive types. The flexible drive architecture lets companies change from a stepper motor to a servo and vice versa. It supports up to two axes with performance levels of 500 W each on one module and requires a base surface of less than 50 cm2/axis.
The ACOPOSmicro can be used in a nominal voltage range from 18 to 80 Vdc for low-power applications. State-of-theart semiconductors ensure little heat loss, eliminating the need for expensive cooling devices.
B&R Industrial Automation Corp.
1250 Northmeadow Pkwy.
S-100
Roswell, GA 30076
(770) 772-0400
www.br-automation.com
