Enclosures keep water out
Feb. 6, 2003
Null
Top is sloped down 20° so water runs off and no one places objects on top of enclosure. 1.5° sloped door flange promotes run-off and prevents leakage.
Optional leg kits raise enclosure off the floor to facilitate complete washdowns and come in fixed and adjustable models to accommodate sloped floors. (Optional 1 and 6-in. stainless-steel wall standoff kits minimize contact between wall and wall-mounted enclosures while providing support).
Bullet-style hinges lift off for easy cleaning inside and out. Door edge cutouts enable washdowns to clean hinges. Smooth #4 finish provides maximum surface run-off.Foam-in-place gasket eliminates seams and resists high-pressure washdowns. UL 4X latches provide tight seals
Equipment in food, beverage, and pharmaceutical processing plants must withstand daily washdowns to maintain sanitary conditions, and so do the enclosures holding electronics and controls. The enclosures must also prevent water from pooling and creating a breeding ground for bacteria. That's why Hoffman, Anoka, Minn. (www.hoffmanonline.com), designed its Watershed line of enclosures. The stainless-steel wall and floor-mounted enclosures facilitate washdowns while protecting sensitive electronics. There are 36 standard models in a variety of sizes available. Floor-mounted models can be equipped with or without disconnect provisions.
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
