The FEA results from a modal analysis for an engine block appear in FEvis Viewer. Users in this example can examine deformations from modes seven to 10. In addition to the menu selection on the inset window, several icons at the top let users zoom on the part, view it as an isometric, see it from different sides, and examine the deformed and undeformed block. |
FEvis Publisher supports the import of finite-element models in Nastran (.nas, .dat) and Femap Neutral file (.neu) formats. Result formats include Nastran F06 (.f06), and Femap neutral (.neu) and binary results (.fno). Nastran Output2 (.op2) will be available soon. The developer says the viewer can do all that the Publisher can, except import FE models and results. The viewer can be distributed at no cost. The creator of the e-FEresults package can generate views or scenes that call attention to particular results and views, which can be redisplayed from within the Viewer.
The $895 FEvis Publisher includes the FEvis Viewer. A free evaluation copy is available from the developer's Web site.
Global survey samples FEA practices
NAFEMS, the National Agency for Finite Element Methods and Standards in the U.K., is conducting a world-wide survey on the state of finite-element practices. The survey is being carried out by FENet at www.fe-net.org/survey, a network of 110 organizations covering industry sectors that include aerospace, land transport, biomedical, civil construction, consumer goods, marine and offshore, power and pressure systems, and process and manufacturing. The objective is to improve the quality of industrial applications of finite-element technology and the level of confidence that can be placed in its results.
The network encourages users to exchange experience and knowledge across industrial sectors. Results will be available to all respondents. In addition, it is anticipated results will provide the basis for other studies, such as input to technical strategies and roadmaps, and identify areas of competitive advantage along with areas for development.
