Hall-Effect Joysticks
May 5, 2005
Standard HFX line of joysticks is form-fit for easy panel mounting.
Available with a variety of limiter plates, handles, mounting, and output options. Seven models include two axis, two axis with button, three axis, three axis with button(s), and low profile, three axis. Flush, drop-in, raised, snap-on, rear mounting. Joystick travel to 36° (18° from center). Designed with high-impact, glass-filled nylon housing, corrosion-resistant stainlesssteel pivot pins, durable rubber boot and sealing gasket, reliable, noncontacting Hall-effect sensors. Supply voltage of 5 V, response of 40 to 80 sec, and output current of ±2%.
CH Products, OEM Div.
970 Park Center Dr.
Vista, CA 92083
(800) 240-7282
www.chproducts.com/oem
