Locate new products
Jan. 1, 2005
We strip out the fluff and present only the quantitative information about new product releases.
Powerful but efficient motors
DS 28 Series of motors with extreme field weakening combines the advantages of high efficiency, high overload capacity, and constant power range of 1:10.
FEATURES & BENEFITS
  • Maximum torque output to 2,150 N-m
  • Low moment of inertia
  • Continuous torque at standstill up to 800 N-m
AMK DRIVES AND CONTROLS INC.
Richmond, Va.
(804) 222-0323
www.amkdrives.com
Circle 135
Rack-and pinion to go
Off-the-shelf, rack-and-pinion drives include helical and straight tooth versions in multiple sizes, materials, and quality levels.
FEATURES & BENEFITS
  • Metric pitches from module 1.0 to 10.0
  • Force capacities to 31,000 lb
  • Rack segment lengths to 3.00 m
  • Grades include soft, induction-hardened, quenched and tempered, and AGMA 12 hardened and ground
  • Specials and modifieds possible
ATLANTA DRIVE SYSTEMS
Wall Township, N.J.
(800) 505-1715
www.atlantadrives.com
Circle 136
Couplings and connection brochure
A new brochure details the variety of materials, coil configurations, bore diameters, and attachment methods available for flexible couplings.
FEATURES & BENEFITS
  • Couplings compensate for misaligned shafts and work at high speed, transmitting high torque at a constant velocity
  • No backlash and require no maintenance
HELICAL PRODUCTS CO. INC
Santa Maria, CA
(805)928-3851
www.heli-cal.com
Circle 137
Precision ballscrews
Ballscrews with elastic spacers separating recirculating balls consistently achieve slow, fine motion down to 1 µm/sec.
FEATURES & BENEFITS
  • Elastic spacers under slight compression eliminate inter-ball friction and associated problems such as servo loop instability and intermittent idling torque spikes
  • Special spacer shape — two back-to-back Belleville springs with a hole in the middle — ensures sustained close guidance during recirculation, while preventing cracking during overload by allowing adjacent balls to touch
  • Spacers do not limit the number of load balls compared to spacer-less ball nuts, and by storing lubricant, they can extend ballscrew life
STEINMEYER INC.
Bedford, Mass.
(781) 275-6097
www.steinmeyer.com
Circle 138
Space-saving encoder
Hollow-shaft encoders mount directly to machine shafts without couplings, saving time and space.
FEATURES & BENEFITS
  • Industry standard 58-mm diameter housing with a mounting profile less than 2 in.
  • Torque rest prevents rotation in direct mount applications
  • Produces up to 5,000 ppr at 200 kHz
  • Available in 10 or 12-mm shaft bores
  • Runs on 5 Vdc or 10-30 Vdc
PEPPERL+FUCHS
Twinsburg, Ohio
(330) 486-0001
www.am.pepperl-fuchs.com
Circle 139
Tiny motor with integrated encoder
Micromotors for demanding applications generate 10 mNm of constant torque with an output power of 9 W.
FEATURES & BENEFITS
  • Compact design (22 × 32 mm) uses NdFeB magnets
  • Precious metal commutation accommodates low starting voltages
  • Encoder adds only 1.4 mm to the overall length of the motor, and is insensitive to dust, dirt, and light
  • Two quadrature output signals deliver up to 512 pulses/rev/ channel
MICROMO ELECTRONICS INC.
Clearwater, Fla.
(727) 572-0131
www.micromo.com
Circle 140
Electromechanical actuators
TA Series electromechanical actuators handle 500 and 1,000-lb loads.
FEATURES & BENEFITS
  • Aluminum housing and outer tube; stainless-steel translating tube with urethane wiper
  • Travels to 52 ipm
  • Operating temperature: -20 to 120°F
DUFF NORTON
Charlotte
(800) 477-5002
www.duffnorton.com
Circle 141
Rotary encoders
The ERO 1470 is available without integral bearing and with integrated electronics, making it well suited for the electronics industry.
FEATURES & BENEFITS
  • Displays up to 25-fold interpolation of the scanning signals
  • Installation diameter requirement of 44 mm
  • Shaft diameters: 4, 6, or 8 mm with line counts of 1,000 or 1,500
HEIDENHAIN CORP.
Schaumburg, Ill.
(847) 490-1191
www.heidenhain.com
Circle 142
Torque flange sensors
TF Series torque flange sensors' robust construction lets them work in harsh environments.
FEATURES & BENEFITS
  • Antenna doesn't need to loop around sensor
  • Protective cover can mount close to sensor without affecting signal quality
  • Torque from 50 to 50,000 N-m; accuracy of 0.1 to 0.25%; 200% overall load capacity; 400% overall limit
MAGTROL INC.
Buffalo
(716) 668-5555
www.magtrol.com
Circle 143
Brushed-type dc motors
Arrow motors offer long life at a competitive cost.
FEATURES & BENEFITS
  • 60, 90, and 110-mm diameters for NEMA 23, 34, and 42 frames
  • 12, 24, 36, and 48-V windings for compatibility with most standard motor drives
  • Torque from 40 to 2,100 oz-in.
  • Unique windings, modified shaft lengths, and custom flange dimensions possible
MOTORSOFT INC.
Thousand Oaks, Calif.
(513) 934-4598
www.arrow-motor.com
Circle 144
Dc motor controllers
On-Motor controllers can be custom designed completely within Pittman brushless dc motor frames.
FEATURES & BENEFITS
  • Eliminates boxes, wires, and bulk
  • Enables multi-wire brushless dc motors to be converted into simple two-wire motors with open-loop speed control in voltages from 12 to 48 V; currents to 8 A; and shaft speeds from 100 to 15,000 rpm
PENNENGINEERING MOTION TECHNOLOGIES
Harleysville, Pa.
(877) 748-8626
www.pennmotion.com
Circle 145
Special linear motion components
A line of special linear motion components consists of guideways for special machines, modified standard guideways, replacement guideways, and custom products.
FEATURES & BENEFITS
  • Components include V guides, double V guides, guide racks, prismatic guides, profile rails, and gear racks
  • Range of materials and cross sections available
  • Single rail lengths available to 2,000 m; maximum width is 150mm and maximum height is 50mm
SCHNEEBERGER INC.
Bedford, Mass.
(800) 854-6333
www.schneeberger.com
Circle 146
Dc gearmotor
Model MMP.PDSG35-12V.400.1 miniature 12-Vdc motor accepts power even from batteries.
FEATURES & BENEFITS
  • Ø37 × 61 mm, mounting with six threaded holes
  • 400:1 ratio, rated for 94 oz-in. continuous torque, 0.5 A, 12 rpm under full load
  • Options include integral optical encoders, failsafe brakes, analog tachometers, ratios from 2:1 to 3,000:1
  • Planetary arrangement and low-backlash gearing also available
MIDWEST MOTION PRODUCTS
Watertown, Minn.
(952) 955-2626
www.midwestmotion.com
Circle 147
Triple-axis controllers
The TMCM-303 and TMCM-310 three-axis controllers provide a complete motion control system in a small size.
FEATURES & BENEFITS
  • 1.5-A/phase output; supports 16x microstepping
  • Remote controlled by a hose via CAN, RS232 or RS485 interfaces
  • Built-in ramp generator for autonomous positioning and speed control
  • RS232 level shifter, two optional 12-bit ADC inputs, SPI controllable by an external master, and reset button available on the TMCM-310
LIN ENGINEERING
Santa Clara, Calif.
(408) 919-0200
www.linengineering.com
Circle 148
Inverter duty gearmotors
New gearmotor line designed specifically for adjustable-speed control.
FEATURES & BENEFITS
  • TEFC motor (3/8 hp, 230 V, 60 Hz)
  • Right-angle and parallel-shaft gear configurations
  • Gear ratios: 5:1 to 75:1 (right angle); 5:1 to 30:1 (parallel)
  • Torque range: 38 lb-in. to 350 lb-in.
BALDOR ELECTRIC CO.
Ft. Smith, Ark.
(479) 646-4711
www.baldor.com
Circle 149
Upgrade control card
Kollmorgen SAC card transforms servoamplifiers into fully programmable motion control drives.
FEATURES & BENEFITS
  • Provides machine-control functionality to eliminate simple PLCs
  • Wizards, MC BASIC, full math capability, multitasking language for enhanced control
  • Support for CANopen for use in larger distributed control system, or on one axis
  • Supports linear, rotary, direct-drive motors; incremental or absolute positioning; low and high inertia applications
DANAHER MOTION
Wood Dale, Ill.
(866) 993-2624
www.danahermotion.com
Circle 150
Roller cam followers
Rugged roller cam followers solve some of the toughest machine and product control guidance challenges.
FEATURES & BENEFITS
  • Double row of cylindrical rollers doubles dynamic load rating
  • Five times longer operating life than comparable followers
  • No lubricated required
  • Runs at twice the speed of normal followers
  • Sizes begin at 1-in. diameter with special configurations and finishes available
RBC BEARINGS INC.
Fairfield, Conn.
(800) 390-3300
www.rbcbearings.com
Circle 151
High-precision rack and pinion
A precision rack and pinion system provides smooth running and low noise.
FEATURES & BENEFITS
  • Produced to Quality 2 (AGMA-14) per DIN standard 3961
  • Wear-resistant surface treatment and high-accuracy teeth
  • Linear accuracy of 12 µm/500 mm of rack length
  • Load capacities to 14,500 N are available at speed to 240 m/min
ALPHA GEAR DRIVES INC.
Elk Grove Village, Ill.
(847) 439-0700
www.alphagear.com
Circle 152
NServo digital controller
New control module retrofits analog motion control systems with digital controls.
FEATURES & BENEFITS
  • Supports two standard or four closed-loop servo axes
  • Each control axis has a three-phase ±10 V output allowing it to drive any amplifier
  • Software configurable for brush, brushless, and stepper motor operation
  • FireWire enabled, optional Ethernet port for additional I/O
AEROTECH INC.
Pittsburgh
(412) 967-6854
www.aerotech.com
Circle 153
