Proximity Sensor Has Extended Range
Jan. 6, 2005
The MetalHead proximity sensor is targeted for rugged applications.
A PTFE coating prevents foreign material, even weld splatter, from adhering to the stainlesssteel housing and mounting hardware. The sensors have an extended sensing range of 2 mm for the 8-mm diameter sensor and 4 mm for the 12-mm sensor. Operating power is from 10 to 30 Vdc in npn, pnp, or dc two-wire models. A high-intensity LED output sensor is viewable from a distance.
HTM Electronics Industries,
8651 Buffalo Ave., Niagara Falls, NY 14304,
(800) 644-1756, htm-sensors.com
