SMT Package Emulation
Sept. 16, 2004
The SF-MLF32A-A-02 small-footprint Surface Mount Package Emulator Foot for 5-mm body, 0.5-mm pitch pins such as the Cypress PSOC CY8C2XXXX family.
This device has pads on the bottom that precisely match the pin layout for the MLF/QFN package including the E-pad or heatsink pad in the center of the pattern. This allows connection to an MLF land pattern of target board to provide a set of interconnects available for probing or connecting to another assembly. The top of the SF-MLF32A-A-02, after being attached to the target, consists of female, machined socket pins with all gold plating for maximum reliability. Compatible gold-plated male pin adapters are then plugged in. Other sizes of MLF SMT adapters are available in the same product line from 28 to 64 pins.
Ironwood Electronics Inc.,
990 Lone Oak Rd., Suite 120, St. Paul, MN 55121,
(800) 404-0204, www.ironwoodelectronics.com
