Benefits of Pin and Sleeve Connectors Over Standard Twist Lock
Sponsored by LAPP Group
Pin and sleeve connectors seal power connections and insulate power delivery from moisture, grime and chemicals. They’re designed to prevent disconnecting under load, and are often used for applications with abusive environments. Pin and sleeve devices range from metal-housed products to high impact-resistant plastic products with varying designs. Download our whitepaper and learn why pin & sleeve connectors are a safe and cost effective option for your wiring requirements.
TAGS: White Papers
