Three multi-pump control solutions are offered: single-drive multi-pump, multi-drive multi-master and multi-drive multi-follower. One AC drive controls a lead pump for single-drive installations and in multi-master mode, each pump is controlled by its own AC drive. Additional fixed-speed pumps can be brought online directly or with a soft starter if demand exceeds the capabilities of the pump. Users can choose between fixed setups and solutions for the lead and auxiliary pumps to alternate roles and equalize wear and tear.
The VACON 100 FLOW is available in a number of frame sizes with either UL Type 1 (IP21) or UL Type 12 (IP54) approved enclosures. It covers the power range of 0.75 HP (0.55 kW) to 250 HP (160 KW) and the voltage range of 230 V to 500 V.
VACON, Runsorintie 7, 65380 Vaasa, Finland, +358 (0) 201 2121
