Variable-Speed Drive Works Quietly
Dec. 9, 2004
Series VSD (variable-speed-drive) pumps operate on 10 to 29 Vdc, for installations in either 12 or 24-Vdc electrical systems.
Variable-speed drive works quietly
The unit pumps 4.5 gpm, and the 10-A Model draws less than 1 A at low flow. The Sensor VSD 3.7 pumps at 3.7 gpm and draws 8 A. The units are aimed at RV, marine, beverage, and industrial applications. The latest is the RV/Marine water-system pump. The VSD Water Pressure System needs no pressure switch. Operation is sensor controlled by a microprocessor. As more water is needed, the motor responds to drive the pump for more flow. Conversely, as demand lessens, the motor slows to a "super quiet speed," still maintaining a steady system pressure. The smooth performance eliminates the need for an accumulator tank.
Plumbing for the VSD Water Pressure System has no pulsation,-water hammer, or temperature swings. Several models are available. One handles boats and RVs to 30 ft, and the other is for larger systems with higher demand.
Flojet Corp.,
20 Icon, Foothill Ranch, CA 92610,
(949) 859-4945, flojet.com
