Why Machine Builders Should Move Beyond the Control Cabinet
See how to free skilled electricians for higher-value work, eliminate wiring errors, and cut assembly from 24 hours to 1 hour.
Feb. 13, 2026
Sponsored by
beckhofflogo_3
Machine builders track material costs and floor space closely. But some of the biggest costs reveal themselves later, in warranty calls, cooling maintenance, and skilled labour shortages.
Cabinet-free automation with MX-System eliminates these costs at the source, delivering measurable savings on every machine you build.
Download the latest Beckhoff guide to learn how MX-System can help you:
Cut control panel assembly from 24 hours to 1 hour
Reduce dependency on skilled electricians through plug-and-play systems
Ship globally with pre-certified modules (cULus and CE compliance built in—no panel redesign for each market)
Ship one machine design to any market with built-in global certification
Adopt cabinet-free automation incrementally without redesigning your entire system
