Space constraints, load precision, and performance demands are pushing engineers to rethink standard compression spring design across industries like aerospace, medical, and automotive. When a conventional coil spring replacement is needed, understanding the wave spring versus coil spring decision becomes critical to getting the right result. This guide breaks down five criteria for determining when a wave spring outperforms a traditional wire coil spring.
Readers will learn how a flat wire wave spring achieves the same force and deflection as a round wire coil spring in up to 50% less axial space, and why that matters for compact electronics and aerospace components. The guide also explores how Crest-to-Crest wave spring configurations deliver even, predictable load control for both static and dynamic applications, plus how the edgewinding manufacturing process opens up design flexibility that traditional coil springs can’t match.
The guide walks through what happens when a part has to perform reliably across shifting conditions such as vibration, varied pressures, and duty cycles that push standard components to their limits, and why material choice can make or break long-term performance in cryogenic, high-heat, or corrosive settings.
These five considerations offer a quick way to check if a wave spring belongs in your next design.
