Remcon Equipment, Inc.
2207 S. Lawson St.,
Airway Heights, WA 99001
United States of America
509-244-9439
More Info on Remcon Equipment, Inc.
Remcon designs and manufactures custom conveyors, hoppers, chutes and platforms for recycling and material handling. Services include installation, repair, refurbishment, belt replacement and equipment relocation.
Products
Courtesy of Remcon Equipment, Inc.
Remcon heavy-duty roller chain baler feed conveyor.
Supplier Submitted
Remcon builds roller chain belt conveyors for recycling and heavy-duty material handling. Chain-mounted steel rollers travel on rails, reducing drag while sprockets provide positive...
Supplier Submitted
Remcon builds custom slider bed conveyors for recycling, solid waste and OEM production lines. Rubber or PVC belts slide over replaceable steel slats, reducing the number of moving...
Supplier Submitted
Remcon fabricates troughing idler conveyors for bulk material handling. Angled rollers support the belt in a trough to contain loose material and reduce sliding friction. Applications...
Supplier Submitted
Remcon's drag chain belt conveyors use two strands of chain connected by steel cross members, with rubber or PVC belting bolted to the carrying surface. Sprockets provide positive...
Supplier Submitted
Remcon builds beltless drag chain conveyors with steel cross angles bolted between two strands of chain. The flights move material along a solid steel bed, providing a durable...
Contacts
Sean Johnston
CEO
Remcon Equipment, Inc. Categories
Request More Information From Remcon Equipment, Inc.
