Scanning For Ideas: Heavy-Duty Motors Can Handle Overspeeds
Permanent magnets are on the rotor and windings are on the stator. The motors turn at 1,800 rpm despite temperatures from 0 to 40°C, but can be run faster if an application requires. The windings withstand temperatures to 150°C, while the wiring withstands 200°C and resists moisture. The motor is housed in a sealed TENV enclosure and the motor is UL, CE, and cUL listed. High-energy neodymium magnets ensure high-torque density. The units have NEMA 42/56 for base mounts.
