Harnessing Low-Code Platforms for Rapid Industrial Automation
Today’s modern factory floor is emerging as an efficiently automated ecosystem, intricately woven into the organization’s infrastructure and supply chain systems. The Industrial Internet of Things (IIoT), artificial Intelligence (AI), hyper-automation, advanced analytics, cloud computing, digital twins, mobile applications and cybersecurity are converging to add phenomenal value to Industry 4.0 in its quest to achieve connected and data-driven operations.
According to PwC’s recent Global Industrial Manufacturing Sector Outlook, close to 50% of industrial manufacturers are expected to automate their key processes by 2030. As impressive as this sounds, it must also be said that many manufacturing organizations struggle with fragmented automation landscapes, thanks to siloed data across enterprise and shop-floor systems.
Here is where low-code development platforms provide a promising path for rapid industrial automation. In combination with modern data architectures such as Unified Namespace (UNS), they provide extremely swift and scalable ways to enable faster deployment cycles and comprehensive collaboration between engineering, IT and operations.
What Low-Code Platforms Bring to the Table
Modern low-code platforms provide intuitive visual development environments, reusable templates and pre-built integration connectors that significantly reduce development complexity. By strengthening the connectivity between an enterprise´s core systems, they harness the power of the data that the systems collect with intelligent insights to improve operations and business outcomes, as well as to enable hyper-automation at scale.
A growing number of industrial enterprises are adopting UNS architectures as the central data fabric of the enterprise. This approach enables real-time and event-driven communication across various manufacturing systems—from IoT sensors and edge devices, to PLC and SCADA, to ERP and supply chain—for consumption by enterprise applications.
Low-code platforms act as orchestration and experience layers above UNS. They enable organizations to rapidly build applications, leveraging unified real-time data streams without complex integration development.
Supported by platforms such as Salesforce (through MuleSoft and Oracle), enterprise integration ecosystems enable structured workflow automation and enterprise orchestration, while UNS provides real-time operational data consistency.
With their reduced costs of set-up, training, deployment and maintenance, low-code platforms are also affordable for small and medium-sized manufacturer. As well, their flexibility and openness allow for future scalability and enhancement.
Making Speed a Competitive Advantage
According to Forrester Research, low code application development is 10-20 times faster than traditional methods. This enables organizations to rapidly implement automation across the various dimensions of their operations, including product design and development, production, maintenance and supplier management.
Low-code applications can deploy pre-configured modules and templates, in addition to reusable elements, enabling businesses to fast-track development cycles and achieve seamless scaling of production processes. When deployed alongside UNS architectures, the speed advantage increases further as applications consume standardized, contextualized data streams instead of point-to-point integrations.
Key use cases that benefit from industrial automation include:
- Predictive maintenance workflows, triggered by UNS event streams.
- Shop floor production scheduling, integrated with enterprise planning systems.
- Supplier onboarding and digital supply chain orchestration.
- Quality monitoring and compliance automation.
Additionally, when combined with connected data architectures, low code can significantly accelerate operational transparency and customer engagement.
AI, Low Code and UNS
The convergence of unified real-time data through UNS, low-code application development and embedded AI-driven decision intelligence is all set to introduce the next evolution of industrial automation.
The next generation of industry AI and automation will see three core elements working in seamless synchronization: 1) an efficient aggregation of data for real-time access to information to enable smarter operations; 2) advanced algorithms and AI to analyze and process data for actionable intelligence in industrial automation; and 3) embedding automated decision-making and action into the workflow.
Imagine a scenario, in which a UNS enables AI models to consume real-time contextualized data from across the enterprise, significantly improving prediction accuracy and automation reliability. In addition, low-code platforms enable predictive analytics models triggered by operational event streams, generative AI for workflow creation and optimization, and agentic AI for autonomous decision workflows.
Such convergence will accelerate the emergence of citizen automation, whereby plant engineers, reliability managers and supply chain specialists design automation workflows utilizing real-time operational intelligence.
Cybersecurity and Governance
As industrial enterprises accelerate automation and connectivity, and as low-code industrial automation brings an increasing number of non-technical users into its fold, robust governance and cybersecurity measures become non-negotiable, fundamental requirements.
Especially in UNS-enabled, low-code architectures (which centralize industrial data flow to improve visibility), it is critical that structured security frameworks are in place. Low-code platforms must integrate with industrial cybersecurity standards such as those defined by National Institute of Standards and Technology and International Electrotechnical Commission frameworks (such as IEC 62443).
Key cybersecurity considerations include:
- Zero-trust industrial access through identity-based authentication for applications and devices, accurate segmentation between OT and IT networks, and role-based access to automation workflows.
- Impeccable workflow governance and auditability through version-controlled automation deployments, central monitoring of citizen-developed applications, and audit trails for compliance and regulatory reporting.
- Secure edge-to-cloud communication with encrypted communication across UNS messaging layers, continuous threat detection and anomaly monitoring, and secure API and integration management.
Low-code platforms enable effective governance by providing centralized monitoring, lifecycle management and policy enforcement across automation workflows.
Challenges to Overcome
Implementation of low-code platforms in industrial automation faces its share of challenges, too. Key among them include:
Integration issues with legacy systems, especially as quite a few industrial organizations often operate heterogeneous OT systems and deploy legacy technologies. Such compatibility issues may be addressed through phased modernization and UNS adoption strategies, purposeful customization of API settings and the right choice of the automation platform for smooth infrastructure connectivity. Enterprises need to evaluate platforms based on:
- Native integration with UNS architectures.
- OT/IT convergence and edge deployment support.
- Built-in cybersecurity and governance frameworks.
- Pre-built connectors for ERP, MES and IoT ecosystems.
- Embedded AI and analytics capabilities.
- A strong partner and hyperscaler ecosystem.
Scalability from pilot to enterprise-level implementation can be a real challenge. Organizations must establish governance models that ensure citizen-developed workflows remain secure, maintainable and scalable.
Cross-skilling and upskilling requirements for the workforce must be done right. Low-code adoption shifts workforce skill requirements toward hybrid OT/IT roles. Upskilling plant engineers and automation specialists into citizen developers accelerates innovation without displacing operational expertise.
The aforementioned PwC study finds that today’s global USD $6 trillion industrial manufacturing industry is at an exciting take-off point, with AI, automation, and emerging technologies unfolding vast opportunities for growth. Low-code platforms will increasingly become the default development environment for industrial enterprises, enabling faster innovation cycles, stronger cybersecurity governance and AI-driven operational decision-making.
Being future-ready and future-fit to leverage this opportunity calls for industrial automation to accelerate its strides toward composable, event-driven architectures where UNS acts as the digital nervous system and low-code platforms provide the application intelligence layer.
Chandrakant Deshmukh
Senior Vice President of Connected Enterprise Services (IoT), Mastek
Related
