How AI Transforms Fragmented Data into Actionable Engineering Intelligence
There’s a lot of potential knowledge hiding in your data—knowledge that can be used for faster problem resolution, root cause analysis, process optimization and continuous improvement efforts. For mechanical and design engineers, integrating AI into existing workflows isn’t just about “data science”; it is about enhancing the mechanical reliability and physical output of the plant.
For process manufacturers, AI can help find answers within vast volumes of historical data, including both structured and unstructured datasets. This integration can transform operations, making them more responsive and adaptive to changing conditions.
The Knowledge Problem: Tacit Expertise vs. Equipment Data
Process manufacturing plants generate enormous amounts of data every day, ranging from formal sources like MES systems, maintenance logs and sensor data to informal sources such as shift notes and operator comments. While this data contains valuable insights, it’s often fragmented or written in shorthand that only a seasoned mechanical lead understands.
This issue is compounded by the loss of tacit knowledge. In a mechanical context, this is the intuitive understanding of a specific pump’s vibration profile or the “sound” a compressor makes before a seal fails. Without a way to capture this, plants risk losing the critical insights needed to prevent catastrophic mechanical downtime.
READ MORE: Process Manufacturing Ready to Evolve Again
This is where AI can help. By applying machine learning and natural language processing to decades of operational data (maintenance logs, sensor readings, shift notes), AI can surface relevant patterns and historical precedents in seconds, giving engineers and operators faster access to the institutional knowledge that would otherwise take hours to find, or walk out the door entirely when a veteran retires.
Of course, AI is only as effective as the human expertise guiding it. Analysts including ARC Advisory Group and LNS Research have emphasized the importance of maintaining human oversight in AI applications—particularly in complex operational environments where context, judgment and first-principles reasoning remain irreplaceable. AI can surface the right data in seconds; it takes an experienced engineer to know what to do with it.
Overhauling the Historical Process: A Practical Example
Historically, when a centrifuge in a chemical plant began showing erratic torque readings, the process was manual: A junior engineer would pull paper maintenance logs, talk to a veteran operator who “remembered something similar in ’18,” and spend hours cross-referencing sensor timestamps with shift notes.
READ MORE: Aveva World Conference 2024: Designing for a Connected Industrial Economy
With an AI-driven knowledge platform, the system flags the torque anomaly and immediately surfaces a shift note from three years ago. That note—hidden in unstructured text—mentions that a specific lubricant grade caused similar friction issues during high-humidity cycles. The AI connects the mechanical symptom (torque) with the environmental variable (humidity) and the human observation (lubricant type) in seconds. This transforms the detective work of engineering into a verified decision-making process.
Putting Hidden Knowledge to Work
A robust AI solution for engineering teams includes these components:
- Smart search. Uses natural language processing (NLP) to understand technical jargon and abbreviations (e.g., knowing “HX” refers to a Heat Exchanger). This delivers precise results from years of maintenance logs.
- Solution suggestion. AI analyzes patterns to identify precedents. When a vibration sensor hits a certain threshold, the system suggests likely mechanical root causes—such as bearing wear or misalignment—based on similar historical incidents.
- Conversational AI. This allows engineers to interact with data naturally. An engineer can ask, “What was the discharge pressure on Pump B the last time the seals were replaced?” and get a contextual summary instantly.
How AI Drives Equipment Performance
AI enhances performance across several key areas:
- Problem resolution. Identifying relevant mechanical data in minutes to reduce trial-and-error troubleshooting.
- Root cause analysis. Connecting past mechanical failures with current telemetry to prevent recurrence.
- Process optimization. Monitoring workflows in real time to identify where mechanical parameters (temperature, pressure, flow) can be tuned for peak efficiency.
- Knowledge retention. Digitizing the “tribal knowledge” of retiring maintenance staff to ensure continuity.
Getting Started: A Strategic Approach
- Centralize knowledge management. Consolidate data from MES, LIMS and historian databases with unstructured “human” data such as shift handovers.
- Tailor AI to your mechanical context. Customize tools to fit your plant’s specific equipment language and workflows.
- Invest in adoption. Ensure the engineering team understands that AI is a “co-pilot” meant to handle data-drudgery, leaving them more time for high-level design and optimization.
- Start small. Focus on a single high-value asset—like a critical turbine or reactor—to demonstrate a quick win in predictive maintenance.
By starting with a centralized platform and focusing on bridging the gap between physical machine data and human experience, process manufacturers can unlock the full potential of their operations. In the chemical and pharmaceutical industries, this AI-driven approach is turning “hidden” knowledge into a measurable mechanical advantage.
Andreas Eschbach
Founder and CEO, Eschbach
