Tribology: The Quiet Force Behind Industrial Automation
In industrial automation, every component that moves eventually meets resistance. Whether it’s a robotic arm positioning micro-components or a spindle motor reaching extreme rotational speeds, friction and wear shape performance, efficiency and service life. The discipline dedicated to understanding these forces—tribology—is essential as automation systems demand more precision, higher speeds and longer operating cycles.
Tribology is the study of friction, wear and lubrication between interacting surfaces in motion. It examines how two surfaces behave as they slide, rotate, oscillate or make intermittent contact, and how those interactions impact durability, efficiency and reliability. It is woven into nearly every subsystem of modern automation, from bearings and seals to sensor housings and linear actuators.
Sealing Systems
Seals are among the most tribology-intensive components in automation. Their performance depends heavily on how they interact with fast-moving shafts, rods, pistons and counter surfaces. Materials like polytetrafluoroethylene (PTFE), polyurethane (PU) or engineered plastics with low friction coefficients are often used to reduce heat, prevent premature wear and maintain ingress protection (IP) ratings.
When a seal must support both speed and environmental sealing, tribology-driven material selection becomes the determining factor for system performance. If a seal can offer increased performance and efficiency by even a small percentage, it offers monetary savings for end-users.
High-Speed Automation
High-speed motors and spindle systems have evolved dramatically in recent years. For example, what once qualified as high speed at 800 revolutions per minute (RPM) in a conventional CNC machine is now routinely replaced by motors running 6,000 RPM and beyond, with specialty spindle motors in high-speed machining centers reaching 15,000 to 50,000 RPM.
Each speed tier demands different sealing materials, friction profiles and wear-resistant solutions. At these speeds, even small increases in friction can lead to significant thermal loads. Tribology plays a crucial role in identifying which materials can withstand the resulting temperature rise, how different surface finishes influence wear, where adjustments to lubrication strategies are necessary and what seal geometries can minimize friction without sacrificing reliability.
Sensor Technology
Industrial sensors operate in environments where contamination, vibration, pressure pulses and temperature swings can degrade both sealing performance and housing integrity. Process sensors that measure physical or chemical properties in real time have moving parts that are integral to the sensing technology.
O-Rings, gaskets and custom-engineered components in leading edge materials demonstrate extended sealing performance and wide-ranging chemical compatibility; can dampen vibration; and are suitable for a full range of temperatures. However, high-end discrete sensors like laser or microwave sensors require access ports for setup and calibration. Multi-component sealing solutions—as opposed to single, discrete seals—offer better protection for high-end sensors by integrating the seal into the housing.
For industrial sensors, the cost of failure is high, making tribological evaluation a core part of design. Tribological considerations are essential to ensure that seals maintain their IP ratings and that the materials used can withstand repeated opening and closing during maintenance. They also help prevent fluid ingress from compromising sensitive electronics and ensure that housing components do not experience uneven wear over time.
The Role of Advanced Materials
While elastomer-based oil seals have been the standard for many decades, elastomer seals struggle to stand up to the conditions of today’s electric motors, such as increased rotary speeds, reduced lubrication or dry running conditions. Elastomer seals also create greater friction resulting in high power loss. PTFE rotary lip seals are an excellent alternative, featuring benefits that suit the demands of electric motors and high-speed, critical environments, including:
- Ability to withstand high speeds of up to 100 m/s
- Extremely low friction performance compared to elastomer radial lip seals
- A wide operating temperature range (−100°C to 260°C/−148°F to 500°F)
- Ability to run dry
- Compatibility with most lubricants
- Inertness to most chemicals
- Low break-out force and no stick slip
- High wear resistance
Many component suppliers take a system-level approach to electric motor and electromechanical actuator sealing, often combining PTFE, elastomer and PU components rather than relying on a single material. PU is typically used for dynamic secondary seals, protective elements and molded components where wear resistance, robustness and dimensional stability at speed are essential.
Engineered polymers for dynamic sealing often incorporate specialized additives or molecular structures that reduce friction and dissipate heat more effectively during continuous motion. Leading components manufacturers have custom thermoplastic materials in unique geometries to meet specific application.
Tribology may operate behind the scenes, but its influence is everywhere in industrial automation. From high-speed rotary systems to precision sensors and linear actuators, machinery functions at its best only when friction and wear are strategically controlled.
As automation pushes boundaries in speed, miniaturization and complexity, tribology will continue to shape the next generation of materials, seal designs and motion systems. If the future of automation is faster, more efficient and more reliable, it will be because tribology made it possible.
David Kaley
David Kaley is the former Global Segment Manager, Industrial Automation for Trelleborg Sealing Solutions.
Related
Industrial robotic arms working on an automated assembly lineVoice Your Opinion!
