Robotic helping hand
June 1, 2009
The Robotics and Mechanisms Laboratory (RoMeLa) of the College of Engineering at Virginia Tech, Blacksburg, Va., has developed a robotic hand that can
The Robotics and Mechanisms Laboratory (RoMeLa) of the College of Engineering at Virginia Tech, Blacksburg, Va., has developed a robotic hand that can hold objects as heavy as a can of food or as delicate as an egg, but is dexterous enough to do sign language. Named RAPHaEL (Robotic Air Powered Hand with Elastic Ligaments), the hand is powered by a compressor air tank at 60 psi and an accordion type tube actuator. An air-powered design makes the hand unique, as it requires no motors or other actuators.
Aug. 18, 2025
An inside view of the role precision systems have played in advancing space exploration.
Aug. 15, 2025
Aug. 15, 2025
