Hydraulics hold components on shafts (.PDF Download)
Sept. 4, 2013
The ETP Hydropress bushing from Zero-Max Inc., Plymouth, Minn., holds components on shafts ranging from 80 to 200 mm in diameter, and takes up little space. The bushings handle torques from 21,000 to 200,000 lb-ft using hydraulic pressure contained in a ...
Register or Sign in below to download the full article in .PDF format, including high resolution graphics and schematics.
Clean. Compact. Less heat.
April 16, 2025
