Laser scanner sensor
The TiM310 field-detection laser scanner, enclosed in an aluminum housing with an IP65 enclosure rating, is for anticollision and presence detection.
The unit is about the size of a baseball and weighs around one-third of a pound. The scanner’s 270° scanning range makes it suitable for discrete I/O and field-detection applications in the robotics, logistics, and building-automation industries. With 16 preconfigured fields, the TiM310 can be configured in less than 5 min.
SICK Inc., 6900 W. 110th St., Minneapolis, MN 55438, (800) 325-7425, www.sickusa.com
