Building a Better Caster
The wheels spin on sealed ball bearings and have no center support bar, which reduces surface contact and lets the wheels turn in the direction and that lowers friction. The wheels also have tapered treads and mount on a durable, lightweight aluminum, parabolic wheel face. With these features, a cart equipped with Twergo casters can start moving using 25% less force than that needed for carts with conventional casters.
The thick tread can be made of polyurethanes with a range of different user-chosen hardnesses to meet specific applications. The tread will not pick up debris and help reduce friction. It also wears consistently, so the caster will have a longer life. In fact, the entire caster is designed to last longer than traditional casters, thanks to the rustproof aluminum cores, precision bearings, and lack of exposed joints or linkages. The casters can also handle high-speed applications such as AGVs and tuggers.
Wheel sizes range from 4 × 2 to 12 × 3 in., and can carry up to 4,200 lb. per caster.
Watch these castors in motion, courtesy of Engineering TV:
