Damped-type spring mounts
The V10Z31-... Series damped-type spring mounts are designed for use in corrosive environments with loads from 150 to 750 lb (68 to 340 kgf). The mounts feature mild-steel mounting plates; high-tensile steel springs that are black phosphated; and knitted stainless-steel mesh isolators. The spring mounts are for use in heavy loads, machinery, compressors, pumps, and grain vibrators.
Advanced Antivibration Components (AAC)
2101 Jericho Turnpike
New Hyde Park, NY 11042
(516) 328-3662
www.vibrationmounts.com/newproducts/Spring1.htm
