Edge-welded-bellows design form
The company’s edge-welded-bellows design form is now available online. Edge-welded bellows design is rather complex with the number of variables involved
The company’s edge-welded-bellows design form is now available online. Edge-welded bellows design is rather complex with the number of variables involved. The online form explains each variable and gives users the opportunity to complete the information.
Critical factors in edge-welded-bellows design include the outside diameter, inside diameter, spring rate, pressure range, and temperature range. The form defines each field so users understand why each variable is critical. Two options of the form are available: an HTML Web page for submission of one design and a downloadable interactive PDF file that lets the user download the form, print, and save the information.
BellowTech LLC
1289 N. US Highway 1, Suite 1
Ormond Beach, FL 32174
(386) 615-7530
www.bellowstech.com/contact-us/bellows-designdata-form/
© 2011 Penton Media, Inc.
