Roller-bearing slide table
Roller Bearing Slide Tables with self-aligning linear ball bearings or Teflon composite linear bearings will accommodate a variety of drives. They can be equipped with a precision rolled ball screw or a backlash-free preloaded nut, and are prealigned with matched components for better accuracy and reliability. Designed to be ready for installation and motor mounting when they are received, the tables can use fully supported or end-supported shafting. The tables have thick aluminum end blocks for rigidity. Shaft supports and carriage plates are also aluminum.
Lee Linear, 727 South Ave., Piscataway, NJ 08854, (732) 752-5200, leelinear.com
