Hummon/NIST
The heart of NIST’s next-generation miniature atomic clock ticking at high “optical” frequencies is this vapor cell on a chip, shown next to a coffee bean for scale. The glass cell (the square window in the chip) contains rubidium atoms, whose vibrations provide the clock “ticks.” The entire clock consists of three microfabricated chips plus supporting electronics and optics.
NIST Develops Next-Generation Atomic Clock
May 30, 2019
The newest atomic clock works on optical frequencies that are higher than the microwave frequencies used in the previous generation.
Physicists at the National Institute of Standards and Technology (NIST) have demonstrated an experimental, next-generation atomic clock. It ticks at high “optical” frequencies and is much smaller than other atomic timekeepers: just three small chips plus supporting electronics and optics.
The chip-scale clock is based on the vibrations, or “ticks,” of rubidium atoms confined in a tiny glass container (called a vapor cell) on a chip. Two frequency combs on chips act like gears to link the atoms’ high-frequency optical ticks to a lower, widely used microwave frequency that can be used in applications.
The chip-based heart of the new clock requires just 275 mW of power and, with additional technology advances, could be made small enough to be handheld. Chip-scale optical clocks like this could eventually replace traditional oscillators in applications such as navigation devices and telecommunications networks and serve as backup clocks on satellites.
“We made an optical atomic clock in which all key components are microfabricated and work together to produce an exceptionally stable output,” says NIST researcher John Kitching. “Ultimately, we expect this work to lead to small, low-power clocks that are exceptionally stable and will bring a new generation of accurate timing to portable, battery-operated devices.”
Standard atomic clocks operate at microwave frequencies based on the natural vibrations of the cesium atom, the world’s primary definition of the second. Optical atomic clocks, running at higher frequencies, offer greater precision because they divide time into smaller units and have a high “quality factor,” which is an indicator of how long the atoms can tick on their own without outside help. Optical clocks are expected to be the basis for a future redefinition of the second.
In NIST’s original chip-scale atomic clock, atoms were probed with a microwave frequency. Commercial versions of this clock have become an industry standard for portable applications requiring stable timing. But they require initial calibration and their frequency can drift over time, resulting in significant timing errors.
Compact optical clocks are a possible step up. Until now, optical clocks have been bulky and complex, operated only as experiments by metrological institutions and universities.
Optical ticks in rubidium have been studied extensively for use as frequency standards and are accurate enough to be used as length standards. NIST’s rubidium vapor cell and the two frequency combs are microfabricated in the same way as computer chips. This means the electronics and optics could be further combined and mass-produced, a path toward commercially viable, compact optical clocks.
NIST’s chip-based optical clock has an instability of 1.7 x 10−13 at 4,000 sec., about 100 times better than the chip-scale microwave clock.
The clock works like this: The rubidium atoms tick at an optical frequency in the terahertz (THz) band. This ticking stabilizes an infrared laser, called a clock laser, which is converted to a gigahertz (GHz) microwave clock signal by two frequency combs acting like gears. One comb, operating at a THz frequency, spans a broad enough range to stabilize itself. The THz comb is synchronized with a GHz frequency comb, which is used as a finely spaced ruler locked to the clock laser. The clock thus produces a GHz microwave electrical signal, which can be measured by conventional electronics and is stabilized to the rubidium’s THz vibrations.
In the future, the chip-based clock’s stability may be improved with low-noise lasers and its size reduced with more sophisticated optical and electronic integration.
