Safety sensor
Safety sensor
Nov. 25, 2013
The BNS40S noncontact safety sensor is designed specifically for hygienic and washdown applications. The coded magnet sensor is IP69K rated for use in high-temperature (176°F) and high-pressure (1,450 psi) washdown applications. Made from stainless steel, it resists corrosion and cleaning liquids and meets Ecolab test requirements for washdown with acid and alkaline-based cleaning agents.
Concealed mounting offers a continuous smooth surface without visible screws and, combined with features like rounded edges and fine-polished stainless-steel surface, makes cleaning the switch easier and limits areas where bacteria can grow.
Additional features include a LED for visual status indication; three contacts for safety circuit flexibility; 1, 3, 5, and 10-m prewired cable lengths; and choice of two coded magnet actuators.
Schmersal Inc., 660 White Plains Rd., Suite 160, Tarrytown, NY 10591, (914) 347-4775, www.schmersalusa.com
