Scanning for Ideas: Compact Linear-dc Servomotor
For applications with limited space, the LM 1247 linear servomotor from Micro Mo, Clearwater, Fla. (micromo.com), could be the right fit, measuring 12.5 Ă— 47 mm and weighing 56 grams.
July 24, 2008
It can exert 9.4 N and standard travel is 20 mm, though an option lets it move loads up to 80 mm. The unit has a threephase self-supporting coil, an analog Hall sensor, a nonmagnetic housing, and it does not require lubrication. It is electronically reversible and uses polymer sleeves as rod bearings. Repeatability and precision are 40 and 120 ÎĽm, respectively.
