Thermoplastic makes for fine fit-and-finish
Dec. 12, 2002
The first grill opening reinforcement (GOR) made with thermoplastic will debut in 2003.
The first grill opening reinforcement (GOR) made with thermoplastic will debut on the 2003 Lincoln Navigator and Ford Expedition. Using Rynite PET polyester resin from DuPont, Wilmington, Del. (www.dupont.com/automotive), Ford engineers teamed up with Venture Industries, Fraser, Mich. (www.ventureindustries.com), to design the GOR, which replaces a thermoset sheet-molding compound (SMC) component. Rynite reduces assembly time by eliminating labor-intensive drilling and trimming steps that an SMC GOR requires. Also, the material resists heat sag so warping is less of a problem during e-coat curing at 378°F. Customized water-cooling lets the mold cool in 2 min, down from 8. "The GOR is crucial for the fit and alignment of front end vehicle components," says Nick Stanziola of Venture Industries. "The excellent strength and resistance to warpage from Rynite helps ensure essential parts, such as headlights, stay properly focused and fenders line up precisely with the hood."
July 17, 2024
July 10, 2024
Pumps Push the Boundaries of Low Temperature Technology
June 14, 2024
As an integral part of cryotechnology, KNF pumps facilitate scientific advances in cryostats, allowing them to push temperature boundaries and approach absolute zero.
The entire spectrum of drive technology
June 5, 2024
Read exciting stories about all aspects of maxon drive technology in our magazine.
