WAGO
The 2601 Series from WAGO
PCB-Free Terminal Block Allows Easy Wiring
Oct. 18, 2022
WAGO’s 2601 Series can be connected both vertically and horizontally to a PCB and takes up minimal space.
The 2601 Series is a super-compact, tool-free PCB terminal block with lever technology, allowing quick and easy wiring for cross-sections from 26 to 14 AWG. With the ability to be connected both vertically and horizontally to the PCB and with a pin spacing of just 3.5 mm, this terminal block takes up minimal space on the board.
The Push-In CAGE CLAMP connection technology, solid and fine-stranded conductors with ferrules, can be connected simply by pushing them into the block. The levers ensure that the contact point is always secure, making the PCB terminal blocks ideal for device connections in the field, no matter the performance class.
WAGO
June 27, 2025
June 25, 2025
June 25, 2025
