Adjustable-speed drives
July 7, 2011
The Ringcone (RXC) adjustable-speed mechanical drive is for specialized pumping applications, such as those involving progressive cavity pumps
The Ringcone (RXC) adjustable-speed mechanical drive is for specialized pumping applications, such as those involving progressive cavity pumps. The variable-speed drive uses a ring and cone power train and consists of an input disc, a set of planetary cones, a control ring, the cam disc, and a pressure- control cam. The unit provides a speed range of 0 to 800 rpm.
The RXC features increased low-speed torque, 5× starting torque, and a 2× overload capacity throughout its entire speed range. It is suited for rugged, trouble- free service in explosionproof, chemical processing, and washdown applications.
Nidec-Shimpo America Corp.
1701 Glenlake Ave.
Itasca, IL 60143
(800) 842-1479
www.shimpoamerica.com
© 2011 Penton Media, Inc.
Clean. Compact. Less heat.
April 16, 2025
