Plug-and-play touchscreen
The Status Display Touchscreen, for G9SP programmable safety controllers, displays safety I/O error codes and lets users easily view the status of safety inputs and outputs without installing and wiring indicator lights. Users can reset up to four zones directly from the unit. The plug-and-play touchscreen easily integrates into existing G9SP applications, or is available with the G9SP as a complete programmable safety control and monitoring kit.
The front panel measures 96.0 × 96.0 × 7.0 mm, with an active display area of 58.5 × 58.5 mm. The display is LCD monotone, with 16 shades of gray. It is rated to provide over 1,000,000 touchscreen operations.
Omron Scientific Technologies Inc.
6550 Dumbarton Circle
Fremont, CA 94555
(510) 608-3400
www.sti.com
