Push-to-connect tube fittings
PTC Series push-to-connect fittings provide quick and simple tubing connection/ disconnection and leak-tight performance.
July 7, 2011
All fitting components are stainless steel, including the release collar, making them suitable for use in corrosive environments and in applications requiring “clean” materials. The fittings use captured O-ring face seals to ensure leak-tight operation. Buna-N O-ring seals are standard and fluorocarbon, silicone, and EPDM are also available.
Configurations include 10-32 threaded straight, adjustable position elbow, and adjustable position tee as well as “tube-to-tube” straight union, elbow, and tee models for ¼ and 1 /8 -in-OD tubing.
The fittings can be used with tubing materials such a polyurethane, polyethylene, and copper. For applications requiring corrosion resistance and/or elevated temperatures, the ¼-in.-OD size work with stainless-steel tubing
Beswick Engineering Co. Inc.
284 Ocean Rd.
Greenland, NH 03840
(603) 433-1188,
www.beswick.com
© 2011 Penton Media, Inc.
