Explosionproof I/P transducer
The Type-950XP explosionproof I/P transducer is compliant with ANSI/ISA 12.27.01- 2003 for use with natural gas.
All Type-950 transducers with the natural-gas option will come with the Single Seal marking. The transducers are more compact than dual-seal devices.
The transducer has a built-in volume booster that provides up to 10-scfm airflow capacity to drive large valves, cylinders, and actuators. The unit uses an input signal of 4-to-20 mA and has standard output ranges of 3 to 15 psig, 3 to 27 psig, and 6 to 30 psig with optional field selectable settings. Maximum supply pressure is 100 psig. The transducer is insensitive to position, vibration, supply pressure variation, and RMI/EFI interference.
ControlAir Inc.
8 Columbia Dr.
Amherst, NH 03031
(603) 886-9400
www.controlair.com
