Insidepenton Com Images Top Load Air Filters
Top-load air filters
Sept. 29, 2011
Finite T-Series top-loading compressed air filters are for space-constrained installations. Because the element removes through the top of the housing, there is no need to disconnect drains connections. It has an aluminum housing
Finite T-Series top-loading compressed air filters are for space-constrained installations. Because the element removes through the top of the housing, there is no need to disconnect drains connections. It has an aluminum housing and the filter element removes up to 99.995% of oil, water, and solids from compressed air and other gases with minimal pressure drop. Applications include protecting refrigerated dryers from oil contamination, cold coalescing, and general industrial and OEM filtration.
Parker Hannifin, Filtration and Separation Div.
500 Glaspie St.
Oxford, MI 48371
(248) 628-6400
www.parker.com/finitefilter
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
