Right-angle helical-gear drives
A new series of right-angle helical-gear drives, identified as A 2Z11... Series feature a fiberglass-reinforced nylon housing, hardened steel helical gears, steel shafts, nonmetallic bearings, and both single and double-output shaft configurations. They are base or panel mountable.
Stocked gear ratios are 1:1 and 2:1; maximum rpm is 1,800 and maximum continuous horsepower is 1/8.
Stock Drive Products
2101 Jericho Turnpike, Box 5416
New Hyde Park, NY 11042
(516) 328-3300
http://sdp-si.com/web/html/newprdgearrightangle.htm
