Air process and liquid-circulation heaters
The AHPF Series air-process and liquid-circulation heaters heat low flows of air, gas, water, or aqueous solutions with air/gas flow up to 15 cfm and air/gas out temperature up to 430°C (800°F). Constructed of 316 stainless steel, the heater handles pressures up to 100 psi and 50 W/sq in. For use where clean air is necessary, such as in laboratories, environmental-testing areas, and packaging and sealing.
Omega Engineering Inc.
One Omega Dr.
Stamford, CT 06907
(800) 826-6342
www.omega.com
