Low-power d-a converters
The DAC-12100 Series of low-power, 12-bit digital-to-analog converters have TTL/CMOS compatible inputs. The devices have a 100-MHz conversion rate and are suitable for radar, signal reconstruction, waveform generators, and communications equipment.
The converters have a low glitch-energy characteristic of 3.0 pV-s, compared to the industry norm of 100 pV-s, so they generate little switching noise. Complementary current outputs of 0 to –20.48 mA can directly drive 50-Ω loads. Dynamic performance, to Nyquist at fOUT of 2.02 MHz, provides a free dynamic range specification of – 85 dB.
The converters use R/2R resistor networks and segmented switching current cell arrangement to reduce glitch energy. The resistor network is laser trimmed to give it 12-bit linearity to within 0.5 LSB across the transfer curve.
Datel
11 Cabot Blvd.
Mansfield, MA 02048
(508) 339-3000
www.datel.com
