Helical bevel gear
The KL helical bevel gear is a compact right-angle drive that comes in sizes 1 and 2, and is perfect for packaging, filling, conveying, general automation, and wash down
The KL helical bevel gear is a compact right-angle drive that comes in sizes 1 and 2, and is perfect for packaging, filling, conveying, general automation, and wash down.
The units are smaller thanks to a newly designed, two-stage gear set geometry. The KL1 version is 113.5-mm long, 81-mm wide, and 90-mm deep; representing a volume of only 0.83 liters.
The KL2 is 143.5-mm long, 98-mm wide, and 108-mm deep, for a volume of only 1.52 liters.
The gears feature input speeds of up to 6,000 rpm in cyclic operation and torque ranges up to 65 Nm.
Stober Drives Inc.
1781 Downing Dr.
Maysville, KY 41056
(800) 711-3588
www.stober.com
© 2012 Penton Media, Inc.
