Enclosure junction box
The JB Series junction box for NEMA enclosures is fully compliant with NEMA-1 and UL-50 Type 1 ratings. Constructed of heavy-duty, 16-gauge welded steel for protection against fires and other hazards, the box is appropriate for all types of industrial and commercial electrical wiring, as well as factory-automation applications.
The box features a flat top with removable screws, keyholes for easy assembly, and durable ANSI 65 greypowder coating. Knockouts on all four sides are easily removable and handle industry standard conduit sizes for electrical connections, circuitry, and low-voltage wiring devices. Four wallmounting holes in the back of the unit and an embossed grounding hole in the bottom allow for flush wall mounting.
Bud Industries Inc.
Box 998
Willoughby, OH 44096
(440) 946-3200
www.budind.com/71
