Thin encoder for drives
The 700 Series of encoders feature a thin design and a hollow shaft of up to 25.4 mm, letting them mount directly on a motor’s shaft without an intermediate adapter for shaft reduction. The encoders feature a dual set of heavy-duty bearings and a well-encapsulated enclosure.
A wide range of electrical interfaces are available, including TTL, 1VPP, HC HTL, HTL, and RS-422, each adapted to different frequencies, temperatures, and cable lengths.
Leine & Linde, c/o Heidenhain Corp.
333 E. State Pkwy.
Schaumburg, IL 60173
(800) 233-0388
www. heidenhain.com
