Continuous-motion silicone cables
Highly flexible silicone cables, designed for continuous motion and harsh weather conditions, are suited for use in windmill turbines
April 26, 2012
Highly flexible silicone cables, designed for continuous motion and harsh weather conditions, are suited for use in windmill turbines. These UV-resistant cables are an alternative to PVC and thermoplastic- rubber-jacketed cables that aren’t reliable in severe environments.
The crystal-clear silicone encapsulation is tear resistant, needs no external “armor” or conduit for protection, and will not deform or wear during a lifetime of more than 10 million cycles, even under tight bending radius and constant flexing conditions. The cables are unaffected when exposed to extreme temperatures of –65 to 260°C, ice, snow, saltwater, acid rain, vibration, sunlight, ozone, humidity, mechanical abuse, and most chemicals. An antifriction coating is available for applications that require abrasion and adhesion resistance. The silicone “self-heals” from small punctures and cable jacket damage can easily be repaired in the field
Cicoil Corp.
24960 Avenue Tibbitts
Valencia, CA 91355
(661) 295-1295
www.cicoil.com
© 2012 Penton Media, Inc.
