Epoxy-coated screws
The Deckfast line of epoxy-coated screws, for decks and exterior use, are now available with a star recess in gray, green, red, and tan, in addition to the green and gray square drive versions
June 6, 2012
The Deckfast line of epoxy-coated screws, for decks and exterior use, are now available with a star recess in gray, green, red, and tan, in addition to the green and gray square drive versions.
The fasteners feature an epoxy-based polymer resin coating over zinc plate for corrosion resistance. The screw’s flat heads with nibs ensure greater strength and better countersinking, as well as an auger point for faster, easier entry.
Starborn Industries Inc.
45 Mayfield Ave.
Edison, NJ 08837
(800) 596-7747
www.starbornindustries.com/Deckfast
© 2012 Penton Media, Inc.
