Pilot-control cartridge valves
New 09 Series cartridge valves are for proportional and on/off pilot control of clutches, brakes, and directional-control valves.
June 15, 2012
New 09 Series cartridge valves are for proportional and on/off pilot control of clutches, brakes, and directional-control valves. The hybrid units combine a 10 size cavity with an 08 size tube/coil, providing high flow in a compact package with low-power consumption. They include two on/off solenoid valves and a proportional pressure-reducing valve. The solenoid valves are two position, three way or four way, and operate to pilot pressures of 100 bar (1,450 psi) and flows to 20 lpm (5.3 gpm). The proportional pressure-reducing /relieving valve gives pilot control of a clutch or directional valve. The valve comes with standard reduced pressure settings of 20 and 25 bar (290 and 360 psi) with flow capability exceeding 25 lpm (7 gpm).
Comatrol
1407 Pelzer Highway
Easley, SC 29642
(864) 644-0055
© 2012 Penton Media, Inc.
