Brushless motor/driver package
The BLE Series, a high-performing and energy-efficient brushless motor and driver package, offers a wide and stable speed range of 80 to 4,000 r/min, even if load conditions fluctuate. When used with a hollow-shaft flat gearhead, up to 600 lb-in. of high-permissible torque is possible; and long-life gearheads give the motor a rated life of 10,000 hr. The maintenance-free system features an electromagnetic-brake option suitable for vertical-drive applications.
The motors come in 30-W (1/25-hp), 60-W (1/12-hp), and 120-W (1/6-hp) output power in a round shaft, parallel shaft gearhead, or hollowshaft flat gearhead.
Oriental Motor U.S.A. Corp.
1001 Knox St.
Torrance, CA 90502
(310) 715-3301
