Linear-Motion Accessories
A line of linear-motion accessories include carriage plates assembled from cast-aluminum jig plate, with or without mounted linear bearings; shaft end stops that prevent bearings from coming off the shaft; bellows for shaft and bearing protection in contaminated environments; easy-tomount linear carriage locks for solid positioning of linear slides and carriages; motor mount blocks for coupling motors and ball and leadscrews to slides/carriages; and cast-steel shaft end support blocks.
Lee Linear
727 South Ave.
Piscataway, NJ 08854
(800) 221-0811
