Stacklight towers
The explosion-safe AR- 070 and AR-078 LED stacklight towers for Zone 2 and Zone 22 applications provide user-adjustable audible alarms up to 85 dB (AR-070) and 90 dB (AR-078), and highly visible visual status indication in continuous, flashing, or alarm modes in gaseous and dusty environments. Both models are rated IP65 without alarm/ flashing and IP54 with alarms/flashing. The units feature a glass-fiber-reinforced polyester base, a 1.5-meter cable, and a sealed cable exit. The towers can be wall or direct mounted and can be stacked five high in red, amber, green, blue, and clear.
The AR-070 models are 40 mm in diameter and have an optional ½-in. NPT, and AR-078 models are 60 mm in diameter and have an optional ¾-in. NPT. Installation is simplified with color-coded wiring that is corresponds with the stacklight color. Both models feature interchangeable LED modules that eliminate the need for any rewiring, even after installation.
Patlite Corp.
20130 Western Ave.
Torrance, CA 90501
(888) 214-2580
