Overhung load adaptors
Overhung load adaptors increase radial and axial load support for hydraulic motors and pumps. The units, designed for either face or foot mounting, come in over 50 models with input bore sizes from 5/8 to 3½ in. SAE mounts available include A, B, C, D, E, and F with two or four bolt-mounting flanges. The adaptors are available with many shaft options including splined, threaded, tapered, and extended output shafts. The shafts are precision machined from high-quality 130,000 PSI stress-proofed steel.
Zero-Max
13200 Sixth Avenue N
Plymouth, MN 55441
(800) 533-1731
www.zero-max.com
