See-through filter assembly
Nov. 20, 2012
See-through filter assemblies let users visually see the fluid or oil pumping through the filter to determine fluid condition and inspect the filter element and contaminants/ particles that have been filtered out of the fluid system.
See-through filter assemblies let users visually see the fluid or oil pumping through the filter to determine fluid condition and inspect the filter element and contaminants/ particles that have been filtered out of the fluid system. Users can determine if the particles are from normal use or excessive wear of the bearings and components in the machinery or the engine supplying fluid to the filter assembly. Inspection can be done without draining, leaking, or losing any fluid or oil, and without unbolting or loosening any fasteners or fittings. The filter element comes in micron mesh and can be cleaned and reused.
Clear View Filtration
7320 North Regal St.
Spokane, WA 99217
(509)467-7584
© 2012 Penton Media, Inc.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
