Linear-actuator adapter plates
A new version of the 36-mm G4 linear actuator from Haydon Kerk Motion Solutions includes a special adapter plate to allow this smaller OD unit to replace existing Size 17 hybrid stepper motor linear actuators.
• The unit, with a Size 17 adapter plate, easily replaces existing hybrid units by using the same bolt pattern and pilot surface • Force output from 16 to 58 lb • Output resolution from 0.013 to 0.102 mm/step command • Optimized tooth geometry and high-energy neodymium magnets enable greater continuous force
(203) 756-7441 µ haydonkerk.com
